Brief Description: Starting Off The New Year Right
Installed the oil supply to the gearbox, it used to have its own separate oil supply, now it is constantly being oiled by engine oil pressure, then it overflows to the oil tank. I was not too happy with the given oil line, it seems a bit too short to fit properly. After trying every fitting known to man, I could not seem to find anything that would improve the run, so went the way everybody else did. The problem is that the manifold fits too close to the oil supply port, you cannot add an angled fitting to make it all better. I wish it was a little bit longer hose, but I think it will be OK.
