Don Schwanke's Air Force One
Date: 9-20-2013
Number of Hours: 0.00
Brief Description: HELP IS ON THE WAY!!!
It is amazing how much stuff gets put off when you are one old guy building. Some is because your body is old and stiff and refused to do the job, some is because you need someone to hold a wrench on the opposite side of the firewall or obstacle, and some is because your old body just will not contort and get into the position to do the work! These tasks build up, to a large pile after a while, and keep staring you in the face every time you start something else. My son is coming to help,will stay a couple of weeks and is ready, willing, and able to crawl in those tight spaces and contort his younger body to fit the spaces. I am trying to catch up on delayed tasks, one of which was to remake the fuel tank to make it far better. I got it apart and am about to make it better, you can see the fix in the photos. I also wanted an easier way to add oil to the engne, I think I got a really good solution to that problem as well.
