Gosh why didn't I do this a long time ago! Took about 3 minutes total to get it out of the way, a few more to make it solid when installed, and quick to remove when needed. I spent longer in there after I cut it out than I ever had since I put the rear windows in. Perfetly comfortable to do anything you want anywhere in the cockpit now. Really wonderful! The stick to make the rest of it work will be here Friday from McMaster Carr, total cost of the conversion to removal status will be about $20, and worth ten times that much.
