Spent some time sorting fittings and making some tubing for air and fuel flow. The first photo shows the pipes that will feed the stand pipe and therefore the engine when complete. The next two are just showing the tubing that is necessary to vent the tanks by allowing air in or out depending on wether if you are flying or fueling. I badly need to flip one wing over to the flat stands so I can work on the filler cap assembly, but Geneda says they are too heavy, so am waiting to pounce on the next able bodied man to pass by.
