I had memorized the old guidance, "measure once and cut twice" and made up a wiring cable with that philosophy. While cutting the second time I had a flashback, it was measure TWICE and cut ONCE. Oh well, stuff happens when you get old. Playing with those little pins that I can hardly even see, the center photo shows a crimped pin on a wire, got to do that twice ALSO! The first harness was about two inches too short. I replaced the circuit breakers with the new type, and lost a screw a couple of times, so some Right Stuff on the screw and driver should make it an easy task tomorrow when that Right Stuff is turned to cement, photo three shows my system.
