Solved a problem, it was really easy. A friend from Alaska called and we were discussiog aux fuel tank inlets to the airplane fuel system. I was having trouble until I spotted the ideal spot! Photo 1 is the wing tank connection quick disconnect. I just substituted a T for the 90, added another quick disconnect, and now I have a place to squirt fuel into the wing tanks. I am using a 6.5 gal Moeller tank, will be a snap to lash it down and hook it up, preferable with a pump, electric of course. The last photo is son Mike with his head buried into the tailcone, where he is pulling thru the pitot and AOA lines to go from the ADAHRS unit in the top of the tailcone out to the left wing.
