Did a bunch of stuff today, got a silicone rubber seal around the standpipe to keep stuff from falling down the bottomless hole there, photo one; Took the canopy off and replaced the weak lower ends of plastic with metal ones, remember these from a ways back. Unfortunately the threads were different on the upper end, so had to leave the plastic ones there. Bummer! Then pulled it outside and just had to run the engine again to torment the neighbors, none called the cops though so I guess I am accepted. See it run: https://youtu.be/_1QsxJWS3Fk
