Brief Description: Getting Ready to Resume Real Work
As I heal and become rehabilitated, working on the plane becomes more attractive. Photo 1 is the flywheel revision, I am about to put the ring gear back on with green loctite and heat shrink, wish me luck with only two hands. I had cut the baggage bulkhead to allow access without removing the original tank. With that tank now history, the cut up bulkhead looked pretty shabby with no tank to hide it, plus getting in that tiny hole would not work for me anyway. The tank change also made another problem, there was a big hole in the right side rear window skirt to fill. I just ordered another left side one to put there, with no holes in it
