Don Schwanke's Air Force One
Date: 7-26-2013
Number of Hours: 1.00
Brief Description: Odds and Ends
"Had not installed the fuel pumps, filters, and pressure regulator because my plumbing supply box was missing a few fittings. I layed it all out, made drawings, and tried to identify what I was short. As luck would have it, I completely forgot one fitting (notice to the far right in the photo nr 2, the one filter has no fitting on the right end), and another one I needed two of but failed to change the default web page quantity to 2! Another order off to Summit Racing this afternoon, postage is about as much as the fittings. It is time to get this stuff mounted permanently, and will in fact be the last in the chain to make it so it will run! I also ordered some black felt stuff to cover the glareshield with, I am getting there!"
