"I have been mulling over different air intakes, primarily combustion air. I have finalized it at last, this type scoop built in the upper cowl, will have blast tubes to the gearbox and the spark plugs as well as combustion air. It will also allow heat excape when the engine is shut down instead of trapping hot air in the engine compartment. I intend to copy the P40 style as closely as possible."
