Brief Description: Finally Back to Work on the plane
"I had finally decided to scrap the Vans switch panel and make my own. My friend Darrel had already passed that point, so I just copied his. I think this will work out well and they are in a good location this way, formerly were mounted under the panel. I will fabricate a small loop of rod to provide a steady rest for my hand when having to select alternate systems. I also started sorting and connecting connecting cables, and came to a halt when I could not quite identify a couple of them, confused mess due to wiring for a D180, then changine to a Skyview with conversion cables."
