"It is about time to decide if I want to use the Vans RV12 cowling in photo one, or the Viking one in photo 2. Either one requires a lot of fitting, not only to match the airframe, but also each half has to mate as well. Did a little more hookup stuff, decided where to put the manifold vac lines thru the firewall, since the new manifold will place them at a different spot."
