Brief Description: Lots of time invested in small part
"I just found you cannot post a video on here, only do a Utube load and give a link, like this one here: : http://youtu.be/Tv0TR6rDjwA I finally got the oil system secured, so put in some oil and cranked on the engine a bit. Had been a while since it had been turned over, I wanted to pump up some oil in the system and took a movie of the action. The photos show a modification I did to the oil lines. They were a little tight from the oil cooler change, and they would perhaps be worse with the new manifold that is coming. A pair of 3/8 street elbows made things MUCH< MUCH better."
