Had a lot of interruptions, but got a few things done in the past few days. Brake lines are all installed, will have to cut the lines up front and install the parking brake, Image 3. This works by pulling a choke cable on the panel, moving the lever on the bottom in the photo. You pull the cable, then mash the brakies and fluid is pushed past a check valve and locks the brakes for parking. Something I think Vans should have included in the kit, at least as an option. I must locate it along the brake lines, but out of the way of the Viking fuel module that goes down in that same hole. Just another nice thing you get by going EAB rather than ELSA.
