Some days there is not much to show, but in fact lots got accomplished. This was one of those days. I started out flipping the fuse on its "other" side, so I could finish up wiring stuff that needed access to the left side, found it was easy to flip around, so worked on it in all three positions.. Got that all done, and put on the outside air temp probe, had saved that til as far advanced as I could, since it pokes out and can make some damage if not treated properly. Decided the PTT switches needed to go in next, it is a challenge putting the wires down thru the control stick. I bought after market handle grips and PTT switches, so had to assemble all that as well. Got them all done reaty to put back in the plane and start hooking up some control linkage tomorrow - after I find the parts and pieces to make them..
