Brief Description: See? I told you there was nothing to photograph
Another one of those "invisible days" as Torsten called them. Lots of labor but very little to show for it in terms of dramatic progress. A sharp eyed RV12 builder will recognize I have the entire brake system in, that is the fluid reservoir at the bottom of the first photo, gascolator at about center left. Inside the tunnel, one can see the brakes lines (two of them, one for each wheel you know) fuel supply line and fuel return line, along with the fuel shutoff valve and the little box that measures how much fuel you how much fuel you have used. The brass things on the pedals are the master cylinders.
