Time does drag when you are waiting for your kit to arrive. From others logs I found I needed a bandsaw to make some work easier, so I decided to drag out my band saw for some maintenance. In fact it was made about 60 years ago, and has had no maintenance, probably that was the reason my brother had given it to me some years ago! The rubber wheels had rotted off and I only had one blade. A quick visit to EBay and I found replacement urethane "tires" that apparently last forever, and custom blade makers! Will be as good as new in no time. Still bored since that took such little time, I convinced my dog to play a little poker with me, unfortunately she won.
