Don Schwanke's Air Force One
Date:  3-29-2011
Number of Hours:  0.00
Brief Description:  Getting to Sit and Make Airplane noises!
There is always a need to have a photo of the builder sitting in his pile of parts making airplane sounds. Problem is, I have never heard a 912ULS Rotax, so I just had to use P51 sounds instead.
The plans were quite confusing at this point, so decided to just cleco everything together first and see how it worked out without not having to drill rivets. I think I have it all pretty well figured out, now some dimpling and riveting and it should be done with this part.
As someone pointed out, I was not exactly sitting where the seat goes, I was back up on the center section spar box. No wonder it was so uncomfortable! Actually my knees should be on top of the front most part, in the second photo you can see the hinge part that forms the back of the seat attachment.
