Martin's Web Site
Date:  7-27-2007
Number of Hours:  1.50
Manual Reference:  8-15
Brief Description:  Drilled Rear Spar Attach point
Rechecked proper wing alignment and incidence and then drilled hole for rear spar attach bolt. Started at #30 and worked up to 5/16" using an assortment of drill sizes. Attached bolts and torqued to 100 in-lb minimum spec. Used temporary cotter pins.
