Martin's Web Site
Date:  7-16-2007
Number of Hours:  1.00
Manual Reference:  8-14,15
Brief Description:  Wing Mate Prep Work
Spent many hours over the past week reviewing the instructions, drawings, and other builders blogs for the wing mating and follow-on procedures. Built a detailed checklist of all activities, divided into preparation, mating and subsequent procedures, and after wing removal procedures. Also, cleaned out garage and measured dimensions for clearance. I will be able to put the wing-fuselage assembly entirely in the garage. The target date for performing the wing mate is this Saturday, the 21st. Tonight, I cut the 3" wide wood gauge block for measuring the wing incidence angle. Also, I put together the F664 Control column pushrod and cut the aluminum tube for the flap pushrods.
