Martin's Web Site
Date:  7-5-2007
Number of Hours:  1.00
Manual Reference:  8-14
Brief Description:  Fit Ldg Gear Legs to Mounts
-Deburred main gear legs at gear mount attach point as well as mounting tubes. - Fit gear legs into mounting tubes which was no small matter as the tolerance is very tight. - Match drilled the upper gear leg alignment bolt hole (1 per gear) to 5/16".
