Martin's Web Site
Date:  3-10-2007
Number of Hours:  6.00
Brief Description:  WD-657 Step and Fuselage Disassembly
Drilled and fit the UHMW mounting blocks over the step tube ends. Drilled the blocks to the tube and to the web of the 726 floor ribs. Began the process of disassembling the fuselage for prep and priming. I've decided to go very methodically in reverse order of the assembly instructions. As I remove every piece, I check it against the drawings and perform all deburring, dimpling, etc. Today, I completed the F750 Aft baggage skins and the 722 and 724 baggage ribs.
