Martin's Web Site
Date:  1-7-2007
Number of Hours:  4.50
Manual Reference:  8-9
Brief Description:  Floor stiffener install
Installed floor stiffeners. The alignment of the center stiffeners was not perfect, especially wrt the F601J firewall angles and F783B cover support ribs. In the end, because of the pre-drilled skins, I had to apply shims between the center stiffener angles and the F601J's in order to get a tight joint. These will now require longer rivets than what's called out in the plans.
