Martin's Web Site
Date:  1-1-2007
Number of Hours:  7.00
Manual Reference:  8-9
Brief Description:  Brake/rudder pedal assembly
- Riveted together brake pedals. - Assembled pedals w/ master cylinders onto rudder pedal bars. Found that one left pedal didn't clear the attachment and had to file it down slightly then reprime to get enough clearance to insert a washer and still have free movement. - Drilled out F6116 side bearing blocks for bolts
