Martin's Web Site
Date:  9-16-2006
Number of Hours:  12.00
Manual Reference:  8-4
Brief Description:  Longeron Bending
Spent about 6 hrs today and another 6 over the past week to get the longerons bent properly. Had a lot of trouble w/ the paper template, resulting in me using it to cut a 1/4" plywood one which worked much better. Also used the 721B aft deck to help check alignment. Match-drilled the longerons to the 721B, using the 0.032" shim as described in manual.
