Martin's Web Site
Date:  9-1-2005
Manual Reference:  7-11
Brief Description:  Prime inside of aileron pushrods
Started on 8/30 w/ the cleaning and acid etching of the push rods. Applied 2 coats of AFS water-based primer to the interiors of all four pieces on 8/31. The paint didn't dry uniformly, collecting disproportionately in the bottom of the tubes. Applied another coat on 9/1 and this time set up a hair dryer to help set the paint before gravity could do the same as before. This worked well.
