Martin's Web Site
Date:  8-6-2005
Number of Hours:  4.00
Manual Reference:  7-7
Brief Description:  Fuel Tank Prep for final sealing
Prepared baffle plates for sealing: (1) Deburred them. (2) Polished edges w/ scotchbrite wheel (3) Scored areas that would be sealed. (4) Cleaned w/ MEK Also, did a small sealing session where I sealed on the T408 access plates, covered the screw and ring terminal assembly on the inner capacitance plate and dabbed sealant to attach the sending wire to the vent tube. Recleaned tank surfaces for baffle plate attachment.
