Martin's Web Site
Date:  6-26-2005
Number of Hours:  4.50
Manual Reference:  7-4,5
Brief Description:  Right Wing / Leading Edge Work
(1) Match drilled top and bottom skins to skeleton. Connor removed most of the clecoes on the outboard bottom skin so I could get access for mounting the leading edge. (2) Clecoed together leading edge in cradle and then clecoed to spar. Fluted inboard leading edge rib. (3) Corrected wing cradle problem where I had previously used a main rib as the template for the outboard side of cradle. Removed this side and cut a new one using a leading edge rib. Reassembled the cradle, added extra padding, and then Penny helped me place left wing into cradle.
