Martin's Web Site
Date:  6-18-2005
Number of Hours:  1.00
Manual Reference:  7-8
Brief Description:  Prep rear spar to skin holes
Used deburring bit and drill to lightly remove a small amount of material from each dimpled hole. This was recommended in plans to allow for a better skin fit. Used 0.032" test patch to spot check holes for proper depth. Spot primed holes w/ SEM self-etch primer (3 coats).
