Martin's Web Site
RV-7A
FWF-1
Oil line fittings
Installed the VA-128 restrictor fitting for the oil pressure sensing line.
Installed the 2 oil cooler line fittings in the ports on the engine accessory case.
Installed the AN816-4D manifold pressure gauge line fitting in the bottom right corner of #3 cylinder
RV-7A Home
1805
Cowl/Spinner/Baffles
208
634
Hardware
Systems
412
