Brief Description: Nosewheel Breakout Force and Fairing prep
- Set the torque at 22-lbs per the manual directions. - Drilled through the gear leg, per the instructions. Had to step it up from #46 to #30 and broke several bits in the steel in the process. Took a couple hours to get it done. - Temporarily installed the nose gear in the firewall mount and set it up to start the wheel pant fitting.
