-Fab'd a short section of tubing from the fuel pump outlet that runs forward towards the firewall. I cut it short and prepared it for a coupling for ease of pump installation and removal. I will wait to fab the rest of the fuel line run through the firewall until I know whether or not I need to install a gascolator and where the firewall penetration will be. This is engine dependent. - Trimmed the right fuel tank supply line and bent to fit to the Andair fuel selector valve attach fitting. I ran out of -6D sleeves and nuts, so I will have to order some more along w/ various other AN fittings. - Fabbed the short length of left fuel tank supply line still needed to reach the selector valve. I had put a coupling part way along the line, due to the difficulty of installing a single tube run through the gear weldment. - Fabbed the right brake line from the firewall fitting to a point aft of the fuel pump assembly. Ended it in a 90-deg elbow coupling which will aid in assembly w/ the line that must run through the gear weldment.
