Brief Description: Fin. Ail. Trim, Began Fuel Pump
Secured and aligned the C606 trim links, attached the VA-116 springs and pulled trim system into alignment w/ 0.041" stainless steel safety wire. Secured wire ends and checked for non-interference of trim assembly throughout entire range of motion of combined control column and trim servo position. Began work on high pressure fuel pump by performing sheet metal modifications to F782C center cabin cover and F-983C fuel valve cover. Edge dressed these parts as well as the F-7115B & C covers and the F7115A bottom cover. Dimpled the F7115B &C covers and began to rivet.
