Set up fuselage in driveway. Used roller stand at outboard end and mechanics stool w/ wooden shims at inboard end to support wings. My next door neighbor Dave came over and helped do the install. We installed the right wing first and it went in very smoothly. The left wing was a little more tight and I ended up having to lightly file a bevel on the spar ends in order to get the wing in. Later that evening w/ both wings on, I had several of the folks from work help me maneuver the plane back into the garage.
