Martin's Web Site
RV-7A
WD-657 External Step
Laid out and drilled the holes for the step plate. The plate is steel so it took a good bit of work. Bent and then cut the trailing edge corner to fit the moldline of the compound curve in the F770 fuselage skin.
RV-7A Home
1805
Cowl/Spinner/Baffles
208
634
Hardware
Systems
412
