Bolted tiedown assemblies onto front spar. NOTE: only attached lower aileron bellcrank attach point at this time. Other builders recommended waiting on the upper bracket until ready to assemble the pivot bolt in order to have adequate clearance with the wing skin. Riveted rear spar components together taking care to cleco all holes that needed to be left open for future component attachment.
