Dimpled left elevator parts. Machine countersunk E-714 and E606PP as required. Note: regarding E606PP, I initially dimpled the upper surface in error, so I reversed the dimple direction and carefully smoothed out the dimples. Then, I countersunk the holes using the drill press. 4 of the holes were too deep and will have to be drilled out for an oops rivet. Merry Christmas!!!
