Trimmed to remove interference w/ HS710 and HS714. Must always remember there are no 90-degree corners with metal forming. EVERYTHING must be rounded and filleted...Forgot when cutting these notches and had to go back with the dremel tool, work in a rounded edge and grind off extra flange... In the future, I must remember to drill pilot holes FIRST for all filleted edges...
