Dick Fisher
Date:  11-25-2014
Number of Hours:  3.50
Brief Description:  Installing # 1 TD Formers
I finally received my # 1 Turtle deck formers and was able to
get them installed today. The build manual explains very well
the steps needed to get them installed correctly. The first
step is clecoing the side skins to the # 2 formers and sliding
the bottom edge under the side skins. Then the bottom edge
was matched drilled to the side skin holes.
Next, I had to trim a small amount off the very top flange
on both # 1 formers so they would seat nicely against the
# 2 Formers. I found it was better to hold these formers in
place with one hand at the top and mark two drill holes
with my sharpie pen through the pre-drilled side skins.
I then laid the formers on my table, center punched them
and drilled # 40 holes. Then I placed clrecos in these holes
and proceeded to drill from top to bottom putting a cleco in
each hole as I drilled. Then I up drilled all of the holes to # 30.
Time to call it a day. My next visit will entail tearing the entire
structure apart for deburring.
# 1 TD Formers Installed
Front View of  TD Formers
