Dick Fisher
Date:  9-30-2014
Number of Hours:  4.00
Brief Description:  More Tail Cone Progress
I got alot done in a short amount of time today.
I have the taiI wheel bracket drilled and clecoed.
Then I clecoed the elevator pushrod box sides
and cover into place. Now that I finally found my
angle drill I will be able to proceed drilling some holes
in a few tight spots a regular size drill won't fit.
You can see the turtle deck formers set in place.
They won't get drilled and riveted just yet. I need
to cleco the turtledeck skin in place and then
updrill those holes.
I will be trying out Tony Spicers method of clecoing
the turtle deck formers to the skin and then setting
the entire thing in place on the fuselage to prevent me
from denting or creasing the top skin. The alumnium
is only .020 thick so care must be taken.
The most difficult part of the tail cone assembly is
pulling the plastic sheeting off the large skins. :-)
Right Side
Right Side
Left Side
Left Side
Pulling Plastic
Pulling Plastic
