Dick Fisher
Date:  9-25-2014
Number of Hours:  4.50
Brief Description:  Tail Cone Assembly
I spent the first hour chamfering a radius onto the 4 bulkhead
reinforcement angles so it would fit under the top longeron.
The hour included removing the labels with acetone and deburring
the edges with 150 grit sandpaper. I needed to establish the height
of the reinforcements so I used a spring clamp to hold them into
place on the bulkheads; clecoed one side of the bulkhead to
one of my side skins and then adjusted the height of the angle so
it would fit snug against the upper longeron. Then it was a matter
of drilling & clecoing the parts together.
Next I clecoed all of the bulkheads to my right side skin, lifted that
onto my worktable and then clecoed the left side skin to the bulkheads.
I flipped the box over and laid the bottom skin in place and clecoed
the skin to all of the bulkheads. This skin was kinda floppy at the very
front so I used some spring clamps and the forward rudder cable
guide to stiffen it up. This ensured the skin would fit in the right spot.
I will match drill the bottom skin to the longerons tomorrow and then
updrill all of the holes to # 30 but not the upper longerons just yet.
Before I do that I need to get the turtledeck ready and set in place.
I think I have siad it before but I will say it again. The parts fit together
extremely well. I am very impressed.
Bulkhead reinforcements
Left Side (upside down)
Inside tail cone
Inside tail cone
