Dick Fisher
Date:  9-15-2014
Number of Hours:  4.00
Brief Description:  Building Tail Cone
I received my rear fuselage parts shipment so I spent today
unpacking and do an inventory of parts I received.
I was given a heads up by Rachel the box would contain a lot of
styrofoam peanuts used in protecting the parts. To avoid having to
sweep up a huge pile of this material, I laid the box across my table
and carefully opened one end and began dumping into the trash
can pictured below. I ended up with a 55 gallon garbage bag full
and the trash can about 2/3rds full; so you have been warned !!
The 3rd picture shows the longerons, elevator push rod, aileron
push rods, the bulkhead and turtledeck formers and the elevator
push rod tunnel.
A Big Word of CAUTION: Carefully go through the packing
peanuts you have dumped out as there are some small packages
hiding in there. It would be a shame to unwittingly throw good
parts in the dumpster. I was lucky, found mine before the peanuts
went to the dumpster.
Rear Fuse Skins & Parts
Styrofoam Peanuts
Styrofoam Peanuts
Longerons & Fuselage Parts
