I was pretty busy trying to get this rear fuselage nearer to completion. I installed the tail wheel mount. The plans call for CCP-42 rivets. I ran out of those so just used -44's to finish riveting the mount to the bulkhead. I had previously drilled the 4 bolt holes through the longeron so it was a simple matter of installing the AN 525's. The very aft bulkhead will not be riveted in place until I fit the Vertical Stab.
The second and third pics are of my home made static system. I copied the system from Tony Spicer. I made the aluminum blocks out of 1 X 1 X 1/4" 6061-T6 bar stock. The fittings and tubing were sourced from McMaster Carr. The adhesive cable tie mounts are from the aviation department of Home Depot. If you look closely at the outside skin you can see the large head pop rivet that is partially set and the the mandrel is tapped out lleaving a hollow shell. This system is similiar to Van's RV's.
