Deems RV10 Project
RV-10
Main Spar
10-5-2005
Sec 13
Sec 13 steps 1-4
Rivet Spar extensions to left and right main spars. These spars are BIG and heavy, I had to make an additional work table to butt up to the existing bench
Debur, final drill, anbd lable
Left Spar, had to drill one rivet
4 ft bench 'extension'
RV-10 Home
3113
Access covers and fl
Aileron
Aileron Actuation
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Cabin Cover
Cabin Doors & Window
Cabin Heat
Control System
Electric
Empennage Attach
Empennage Fairings
Engine Mount & Landi
170
Firewall
First Engine Start
Flap System
Flaps
Fuel Tanks
Fuse Side Skins
Fwd Fuse Ribs & BHDS
Gear & Wheel Fairing
Home Stretch
80
348
Horizontal Stabilize
Main Spar
Mid Fuse Bulkheads
Mid Fuse Ribs & Skin
Outboard Leading Edg
Painting Preparation
Panel
Ram Air
Rear Wing Spars
Rudder Pedals & Brak
Seats and Seat Belts
Sec 24 Wing Tips
Spinner and Cowling
Stall Warning System
Steps Installation
Tailcone
Tailcone Attach
Technical Councilor
Top Wing Skins
Upper Fwd Fuse
Upper Fwd Fuse Insta
Vertical Stabilizer
Wing Install
Wing Ribs
Wing Tips
Wing Tips
