Finished the Left wing tip, resquooze the dimples after filing down the dimple die, also used dremel to even the height of the dimples, which I believe was contributing to the puckering/bulging. Installed the tip rib and riveted it. I got some bondo to clean everything up. I'll wait until the Right tip is done and then bondo both.
