I decided that I would go ahead and close up the wings. I've found a hanger where i can store them untill paint & final assembly, and I received the aileron trim kit which is the last item that I plan on adding to the wings, so rather than have this left as an 'open item' I'm goinf to close them out. I've got help scheduled for Saturday, so I hope I can get everything done before then. Today, I stripped the blue vinyl, and clecoed inboard and outboard skins to both wings, and match drilled everything. I had to remove the Gretz heated pitot tube , it look slike it might be a bear to get reconnected after the skins are riveted on, I hope not.
