Deems RV10 Project
RV-10
Fuel Tanks
12-16-2005
Sec 18-8
Sec 18-8 leak repair
Repaired (hopefully) the leaks in the tanks, will let cure for a couple of days and then re-test
only 1 side leaked on this one
Both side leaked here
Ditto
RV-10 Home
3113
Access covers and fl
Aileron
Aileron Actuation
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Cabin Cover
Cabin Doors & Window
Cabin Heat
Control System
Electric
Empennage Attach
Empennage Fairings
Engine Mount & Landi
170
Firewall
First Engine Start
Flap System
Flaps
Fuel Tanks
Fuse Side Skins
Fwd Fuse Ribs & BHDS
Gear & Wheel Fairing
Home Stretch
80
348
Horizontal Stabilize
Main Spar
Mid Fuse Bulkheads
Mid Fuse Ribs & Skin
Outboard Leading Edg
Painting Preparation
Panel
Ram Air
Rear Wing Spars
Rudder Pedals & Brak
Seats and Seat Belts
Sec 24 Wing Tips
Spinner and Cowling
Stall Warning System
Steps Installation
Tailcone
Tailcone Attach
Technical Councilor
Top Wing Skins
Upper Fwd Fuse
Upper Fwd Fuse Insta
Vertical Stabilizer
Wing Install
Wing Ribs
Wing Tips
Wing Tips
