Deems RV10 Project
Date:  11-14-2005
Number of Hours:  3.00
Manual Reference:  Sec 21-3
Brief Description:  Sec 21-3 steps 1-6
Prep the Skins and ribs for Aileron assembly. Also fabricate the stiffeners (32 of these little buggers, takes some time to cut, sand to final size and deburr). Pay close attention to instruction regarding clecoing skins together to check their orientation to ensure that the stiffeners will align correctly. Make sure you mark everything once it is all oriented correctly before deisassembly.
End ribs and doublers drilled
Ditto
Ditto
Cutting the stiffeners (32)
