Deems RV10 Project
Date:  10-17-2008
Number of Hours:  2.50
Manual Reference:  Sec Final-3
Brief Description:  Sec Final-3
After Ed helped me pin the right Elevator in place, I returned today and installed new AN bolts/washers and nuts in the hinges. I'm ready to begin setting / adjusting the trim, but before I do that I need to do some remedial work on some electrical connectons located under the seat (which also control the stick grip functions). I had ignored / overlooked the installation of the mid reai seat supports and had installed a deck I fashioned to hold the door ajar relays. So I needed to remove the relay deck and set aside and then begine to figure out how to install the seat supports with a minimal amount of rewiring, The biggest issue is the pilot side wiring cluster, With the relay deck out of the way (and wires marked and diagramed for reinstallatioin) I began to splice in additional wire lengths to allow for the main wire bundle that runs from the fuse side to the control grip relay to pass behind the seat support. I modified tha aft end of the seat support to allow enough room for the wire bundle and no chaffing between it and the spar. I also added several tywraps to the bundel in that location to further protect the wires. I've still got to lengthen a couple more wires, install the seat support then reposition and reinstall the relay deck. When that's all done I can temporarily connect the center console trim and adjust the trim tabs for travel.
Right side elevator installed
Both elevators installed
Work in process installation of mid seat rail supports.
