Deems RV10 Project
Date:  10-31-2005
Number of Hours:  3.00
Manual Reference:  Sec 18-5
Brief Description:  sec 18-5 steps 1-5LR
Attach shims to Tanks attach bracket assembly, and rivet the Aileron VA 146 bearing in place. This section is not documented well in the plans, it doesn't instruct you to countersink the sides fo the T1005L "& R brackets to accept the shims e.g. also need to study the drawing carefully to get everything oriented correctly.
Shims installed on Left
Shims and bedaring installed/riveted
view from back side
view from back side
